Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Remove the four ZIF ribbon cables highlighted in red by using the following procedure: Use your fingernail to flip up the ZIF cable retaining flap on each socket. Be sure you are prying up the retaining flap, not the socket.
  • Remove the four ZIF ribbon cables highlighted in red by using the following procedure:
  • Use your fingernail to flip up the ZIF cable retaining flap on each socket.
  • Be sure you are prying up the retaining flap, not the socket.
  • Pull the ribbon cable straight out of its socket.
Insertar traducción aquí
