Saltar al contenido principal
Inglés
Español
Traduciendo paso 1
Paso 1
The USB ports are located on the back side of the monitor, below the plastic cover and metallic panel; on the lower left hand side.
  • The USB ports are located on the back side of the monitor, below the plastic cover and metallic panel; on the lower left hand side.
  • The first step is to remove the plastic cover panel.
  • To do so, remove the three 2mm hex screws on the monitor's stand, as well as the four 2mm hex screws located on the four corners of the back plastic cover panel.
  • After removing the mentioned screws, it is possible to take off the panels and began examining the inner components. Make sure main cable i pulled through plastic port.
  • For additional help removing the back panel, refer to the repair guide for the LCD Main Board.
Insertar traducción aquí
