Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 4
The basic internal components of the motor are as follows:
  • The basic internal components of the motor are as follows:
  • Control board
  • Electric motor
  • Plastic drive gears
  • Antenna shaft
  • To operate the antenna up and down, the electric motor turns in the appropriate direction which turns the worm gear. The worm gear tuns the upper plastic drive gear. That spins the lower plastic gear which then moves the ribbed plastic cable inside the cable housing below the gears, all of which you will see later.
Insertar traducción aquí
