Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Inglés
Español
Paso 3
Remove the 10mm nut on the bottom of the shock. Note that if you try to remove this nut you cannot at first as the shaft on the shock turns along with it.
  • Remove the 10mm nut on the bottom of the shock.
  • Note that if you try to remove this nut you cannot at first as the shaft on the shock turns along with it.
  • There is a flat area on the shaft, just above the large metal washer on the bottom portion of the shock. Place a 7mm crescent wrench on this to prevent the shaft from spinning. Pictured from above.
Insertar traducción aquí
