Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Traduciendo paso 1
Paso 1
To remove your motor mounts you will need to raise, and support, your engine with a bottle jack. Before you can do this you will need to remove the bolts that hold the engine to the mounts. This is done from below the car. The bolts are allen head bolts; you will need an 8mm allen head socket. It should be a 1/2 inch drive socket as you will want a large wrench for leverage. These are often in very tightly.
  • To remove your motor mounts you will need to raise, and support, your engine with a bottle jack.
  • Before you can do this you will need to remove the bolts that hold the engine to the mounts. This is done from below the car.
  • The bolts are allen head bolts; you will need an 8mm allen head socket. It should be a 1/2 inch drive socket as you will want a large wrench for leverage. These are often in very tightly.
  • The bolt on each mount is located up inside a recessed area as shown.
  • Remove the bolt and set it aside.
Insertar traducción aquí
