Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 4
Place the de-soldering wick on the solder joint and put the tip of the soldering iron on it so the wick can heat up and absorb the old solder. Please remember that logic board components are very fragile and excessive heat can destroy these components.
  • Place the de-soldering wick on the solder joint and put the tip of the soldering iron on it so the wick can heat up and absorb the old solder.
  • Please remember that logic board components are very fragile and excessive heat can destroy these components.
  • Lift the wick and the soldering iron up from the logic board at the same time. Failure to do so can cause the leftover solder to harden and solder the wick to the logic board and you could easily pull a logic board pad off.
Coloque la mecha de desoldar en la junta de soldadura y coloque la punta de la pistola de soldadura sobre ella para que la mecha se caliente y absorba la soldadura antigua.
Recuerde que los componentes de la placa lógica son muy frágiles y el calor excesivo puede destruir estos componentes.
Levante la mecha y la pistola de soldadura desde la placa lógica al mismo tiempo. De lo contrario, puede hacer que la soldadura sobrante se endurezca y suelde la mecha a la placa lógica y usted podría fácilmente sacar la almohadilla de la placa lógica.
[* black] Place the de-soldering wick on the solder joint and put the tip of the solder gunsoldering iron on it so the wick can heat up and absorb the old solder.
[* icon_caution] Please remember that logic board components are very fragile and excessive heat can destroy these components.
[* icon_caution] '''Lift the wick and the solder gunsoldering iron up from the logic board at the same time.''' Failure to do so can cause the leftover solder to harden and solder the wick to the logic board and you could easily pull a logic board pad off.
