Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 3
You can now see the trunk actuator. It connects to the lock mechanism by the metal rod with a spring.
  • You can now see the trunk actuator. It connects to the lock mechanism by the metal rod with a spring.
  • To remove the actuator begin by removing the two hex head screws. They should be 8mm heads.
  • Then disconnect the two vacuum lines, making note of their orientation. One is for lock (red stripe), one is for unlock (green stripe).
  • Finally, pull the metal armature of the actuator off of the lock mechanism. It pulls off in the direction of the vacuum actuator body.
Insertar traducción aquí
