Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 3
Loosen this ground connection. You will need to remove the turn signal to reach the nut on the back of the bolt that holds those ground wires. For guidance on removing the turn signal click here to review the turn signal bulb replacement guide. Just as you did for the main battery ground clean the area where these wires connect to the chassis. Just as you did for the main battery ground clean the area where these wires connect to the chassis.
  • Loosen this ground connection. You will need to remove the turn signal to reach the nut on the back of the bolt that holds those ground wires. For guidance on removing the turn signal click here to review the turn signal bulb replacement guide.
  • Just as you did for the main battery ground clean the area where these wires connect to the chassis.
Insertar traducción aquí
