Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 4 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 2
Paso 2
Insert your finger underneath the speaker piece and pry away from the phone body. The plastic layer containing the LCD screen and speaker takes some force to remove. There are 4 plastic tabs which keep it in place, but they are hard to press. Be careful and go tab by tab or use a spudger if you are nervous about using too much force.
  • Insert your finger underneath the speaker piece and pry away from the phone body.
  • The plastic layer containing the LCD screen and speaker takes some force to remove.
  • There are 4 plastic tabs which keep it in place, but they are hard to press. Be careful and go tab by tab or use a spudger if you are nervous about using too much force.
  • The LCD and the speaker are attached to the same piece and must be replaced together.
Insertar traducción aquí
