Saltar al contenido principal
Inglés
Español
Paso 6
Pictured here is a piano key, but it has the same connection from the key to the scissor clip as the rest The best solution is to insert the modified spudger below the inside of the key and above the key scissor clip right where the red arrow points (do not insert the tool where the dental pick is here)
  • Pictured here is a piano key, but it has the same connection from the key to the scissor clip as the rest
  • The best solution is to insert the modified spudger below the inside of the key and above the key scissor clip right where the red arrow points (do not insert the tool where the dental pick is here)
  • Then pull downward to release the clip from the tabs labeled with the orange arrows.
Insertar traducción aquí
