Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Paso 10
Without the front case, you will be left with the motherboard and the plastic mount. The LCD screen is attached to the motherboard by a ribbon and can fall off the plastic mount. Using metal tweezers, grab the start/select board and slide it out gently. Using metal tweezers, grab the start/select board and slide it out gently.
  • Without the front case, you will be left with the motherboard and the plastic mount. The LCD screen is attached to the motherboard by a ribbon and can fall off the plastic mount.
  • Using metal tweezers, grab the start/select board and slide it out gently.
Insertar traducción aquí
