Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Paso 4
Remove the two Phillips #00 screws from the plastic frame. As you are pulling off the plastic frame, the shoulder buttons and the volume switch may fall out of the device. Underneath each shoulder button is a small spring. Do not lose them.
  • Remove the two Phillips #00 screws from the plastic frame.
  • As you are pulling off the plastic frame, the shoulder buttons and the volume switch may fall out of the device.
  • Underneath each shoulder button is a small spring. Do not lose them.
Insertar traducción aquí
