Inglés
Español
Paso 15
Remove the four Phillips screws securing the aluminum USB bracket to the outer case. Use a pair of tweezers to pull the flip-up USB axle away from the outer case. Once the axle clears the outer case, the flip-up USB connector may be ejected at high speed. Wear safety glasses.
  • Remove the four Phillips screws securing the aluminum USB bracket to the outer case.
  • Use a pair of tweezers to pull the flip-up USB axle away from the outer case.
  • Once the axle clears the outer case, the flip-up USB connector may be ejected at high speed. Wear safety glasses.
Insertar traducción aquí
