Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Paso 13
Remove the two small silver Phillips screws securing the battery to the outer case. Use a plastic opening tool to pry the battery up off the outer case. The MinoHD sips two hours worth of power from the internal 3.7V, 1150 mAh Li-ion battery weighing in at 30 grams (including bracket).
  • Remove the two small silver Phillips screws securing the battery to the outer case.
  • Use a plastic opening tool to pry the battery up off the outer case.
  • The MinoHD sips two hours worth of power from the internal 3.7V, 1150 mAh Li-ion battery weighing in at 30 grams (including bracket).
  • Coincidentally, that's the same battery capacity as the iPhone 3G.
Insertar traducción aquí
