Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Paso 11
Remove the four silver Phillips screws attaching the logic board to the outer case. To remove the logic board, you must first de-solder the leads of both microphones from the logic board. When soldering on a circuit board, be sure not to heat up the connection excessively. Use a pair of tweezers to gently pull each lead as you heat up the joint with the tip of a soldering iron.
  • Remove the four silver Phillips screws attaching the logic board to the outer case.
  • To remove the logic board, you must first de-solder the leads of both microphones from the logic board. When soldering on a circuit board, be sure not to heat up the connection excessively.
  • Use a pair of tweezers to gently pull each lead as you heat up the joint with the tip of a soldering iron.
  • Repeat this process to remove all four microphone leads. Their locations are boxed in orange on the first picture.
Insertar traducción aquí
