Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 5
Continue prying with an opening pick to separate the Lightning connector assembly from the rear case. Be sure to separate all parts of the assembly from the rear case, including the Lightning connector, headphone jack and home button cable socket. Be sure to separate all parts of the assembly from the rear case, including the Lightning connector, headphone jack and home button cable socket.
  • Continue prying with an opening pick to separate the Lightning connector assembly from the rear case.
  • Be sure to separate all parts of the assembly from the rear case, including the Lightning connector, headphone jack and home button cable socket.
Continúa levantando con una púa para separar el módulo del conector Lightning de la carcasa trasera.
Asegúrate de separar todas las partes del módulo de la carcasa trasera, incluyendo el conector Lightning, el jack de auriculares y el zócalo del cable del botón de inicio.
