Saltar al contenido principal
Inglés
Español
Paso 3
You need detach the heat sink from the CPU. Locate the four clamps holding it down, two on each side. Taking off the clamps can be difficult. Use a screwdriver to push down on the top of the clip. Then insert a spudger below the heat sink to pull it away from the board, releasing the heat sink.
  • You need detach the heat sink from the CPU. Locate the four clamps holding it down, two on each side.
  • Taking off the clamps can be difficult. Use a screwdriver to push down on the top of the clip. Then insert a spudger below the heat sink to pull it away from the board, releasing the heat sink.
Insertar traducción aquí
