Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 31 guías que incluyan este paso.
Inglés
Español
Paso 2
Unplug the left speaker cable by pulling it straight up out of its socket on the logic board. De-route the cable from the gap between the hard drive and logic board. If the gap between the hard drive and logic board is too narrow for the speaker cable, disconnect it and leave the cable in place.
  • Unplug the left speaker cable by pulling it straight up out of its socket on the logic board.
  • De-route the cable from the gap between the hard drive and logic board.
  • If the gap between the hard drive and logic board is too narrow for the speaker cable, disconnect it and leave the cable in place.
Desconecta el cable del altavoz izquierdo de su zócalo en la placa base. Asegúrate de tirar hacia arriba paralelo al zócalo.
Retire el cable a través del espacio entre el disco duro y la placa base.
Si el espacio entre el disco duro y la placa base es demasiado estrecho para el cable del altavoz, desconéctalo y déjalo donde está.
[* black] Unplug the left speaker cable from itsby pulling it straight up out of its socket on the logic board. Be sure to pull straight up out of the socket.
[* black] De-route the cable from the gap between the hard drive and logic board.
[* icon_note] If the gap between the hard drive and logic board is too narrow for the speaker cable, disconnect it and leave the cable in place.
