Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Inglés
Español
Paso 4
Remove the screw that holds the chrome plate behind the door pull. Once again, the 2.5mm allen screw shown is not original. This will normally be a Phillips screw. On the driver's side door, with no upper section of the arm on the door panel, the chrome panel behind the door pull can simply be removed and set aside at this point.
  • Remove the screw that holds the chrome plate behind the door pull.
  • Once again, the 2.5mm allen screw shown is not original. This will normally be a Phillips screw.
  • On the driver's side door, with no upper section of the arm on the door panel, the chrome panel behind the door pull can simply be removed and set aside at this point.
Insertar traducción aquí
