Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 3
There are a total of five 1.6 mm screws which mount the metal chassis to the motherboard. Remove the screw on top and the four screws on the bottom with a #1 Phillips screwdriver. Remove the screw on top and the four screws on the bottom with a #1 Phillips screwdriver.
  • There are a total of five 1.6 mm screws which mount the metal chassis to the motherboard.
  • Remove the screw on top and the four screws on the bottom with a #1 Phillips screwdriver.
Hay un total de cinco tornillos de 1.6 mm que unen el chasis metálico a la placa base.
Quita el tornillo en la parte superior y los cuatro tornillos en la parte inferior con un destornillador Phillips #1.
