Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 9 guías que incluyan este paso.
Inglés
Español
Paso 13
Now that the lower edge of the board is free from the outer case, rotate the logic board toward yourself to expose its rear face. The following connector has a tendency to stick in its socket. If so, insert a metal spudger into the gap between the connecter and its socket. Twist the spudger to separate the two components.
  • Now that the lower edge of the board is free from the outer case, rotate the logic board toward yourself to expose its rear face.
  • The following connector has a tendency to stick in its socket. If so, insert a metal spudger into the gap between the connecter and its socket. Twist the spudger to separate the two components.
  • Carefully pull the optical drive connector away from its socket on the logic board.
  • Pull the connector perpendicular to the face of the logic board.
Insertar traducción aquí
