Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 9 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Pull up on the SATA power cable connector to disconnect it. Unplug the SATA data cable connector by lifting it up. Remove the SATA cable from the logic board assembly to get it out of the way and prevent it from being damaged.
  • Pull up on the SATA power cable connector to disconnect it.
  • Unplug the SATA data cable connector by lifting it up.
  • Remove the SATA cable from the logic board assembly to get it out of the way and prevent it from being damaged.
Insertar traducción aquí
