Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 43 guías que incluyan este paso.
Inglés
Español
Paso 22
Be very careful handling the display—it's big, heavy, and made of glass. The display has fragile edges. Avoid lifting the display by the corners. Lift the display up from the frame and remove it from the iMac. Lay the display face down on a flat, soft surface. It may be necessary to slowly lift from one side, to peel against the remaining adhesive.
  • Be very careful handling the display—it's big, heavy, and made of glass. The display has fragile edges. Avoid lifting the display by the corners.
  • Lift the display up from the frame and remove it from the iMac. Lay the display face down on a flat, soft surface.
  • It may be necessary to slowly lift from one side, to peel against the remaining adhesive.
  • After the adhesive is cut, it cannot be used to re-seal the display in place. Follow this guide when your repair is complete to replace the adhesive strips that secure the display to the rear enclosure.
Tenga mucho cuidado al manipular la pantalla: es grande, pesada y está hecha de vidrio.
Levanta la pantalla del marco y retírala del iMac.
Puede ser necesario levantar lentamente de un lado, para pelar contra el adhesivo restante.
[* icon_caution] Be very careful handling the display—it's big, heavy, and made of glass. The display has fragile edges. Avoid lifting the display by the corners.
[* black] Lift the display up from the frame and remove it from the iMac. Lay the display face down on a flat, soft surface.
[* black] It may be necessary to slowly lift from one side, to peel against the remaining adhesive.
[* icon_reminder] After the adhesive is cut, it cannot be used to re-seal the display in place. [guide|30512|Follow this guide|new_window=true] when your repair is complete to replace the adhesive strips that secure the display to the rear enclosure.
