Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 43 guías que incluyan este paso.
Inglés
Español
Paso 10
Gently twist the plastic card to open the space between the display and frame, and cut any remaining adhesive near the corner. Using too much force will crack the glass. Work carefully, and don't try to create a gap any larger than about 1/4" (6 mm).
  • Gently twist the plastic card to open the space between the display and frame, and cut any remaining adhesive near the corner.
  • Using too much force will crack the glass. Work carefully, and don't try to create a gap any larger than about 1/4" (6 mm).
Gire suavemente la tarjeta de plástico para abrir el espacio entre la pantalla y el marco.
Muévase despacio y tenga cuidado de no estresar demasiado el cristal de la pantalla; solo necesita hacer un espacio de aproximadamente 1/4 ".
[* black] Gently twist the plastic card to open the space between the display and frame.
[* black] Move slowly
frame, and be careful not to stresscut any remaining adhesive near the display glasscorner.
[* icon_caution] Using
too much—you only needmuch force will crack the glass. Work carefully, and don't try to makecreate a gap ofany larger than about 1/4"1/4" (6 mm).
