Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 43 guías que incluyan este paso.
Inglés
Español
Paso 9
While the opening tool did the lion's share of the work, the display will still be slightly adhered to the case. A plastic card will be necessary to free up the last of this adhesive. Set the iMac face-up on a table. Starting from the top right corner of the iMac, insert a plastic card between the display and frame.
  • While the opening tool did the lion's share of the work, the display will still be slightly adhered to the case. A plastic card will be necessary to free up the last of this adhesive.
  • Set the iMac face-up on a table.
  • Starting from the top right corner of the iMac, insert a plastic card between the display and frame.
  • Be careful not to insert it more than 3/8" (9.5 mm), or you may damage internal components.
Si bien la herramienta de apertura hizo la mayor parte del trabajo, la pantalla aún se adherirá ligeramente a la carcasa. Se necesitará una tarjeta de plástico para liberar el último adhesivo.
Coloque el iMac boca arriba en una mesa.
Comenzando desde la esquina superior derecha del iMac, inserte una tarjeta de plástico entre la pantalla y el marco.
Tenga cuidado de no insertarlo más de 3/8 ", o puede dañar los componentes internos.
[* icon_note] While the opening tool did the lion's share of the work, the display will still be slightly adhered to the case. A plastic card will be necessary to free up the last of this adhesive.
[* black] Set the iMac face-up on a table.
[* black] Starting from the top right corner of the iMac, insert a plastic card between the display and frame.
[* icon_caution] Be careful not to insert it more than 3/8"3/8" (9.5 mm), or you may damage internal components.
