Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 5 guías que incluyan este paso.
Inglés
Español
Paso 4
Remove the T8 Torx screwdriver head and replace it with the 60 mm extension; then, add the T9 Torx head.
  • Remove the T8 Torx screwdriver head and replace it with the 60 mm extension; then, add the T9 Torx head.
  • Loosen, but do not remove the two screws at the bottom of the 1.2-inch wide gap in the middle of the internal structure.
  • These screws are spring-loaded and will stay in the device, even when loosened; however, it is still possible for them to be fully removed. Be careful to only partially loosen them.
Insertar traducción aquí
