Saltar al contenido principal
Inglés
Español
Paso 6
In order to remove the motherboard, the flex cables must be demated
Flex Cable Removal
  • In order to remove the motherboard, the flex cables must be demated
  • First remove the four flex cables indicated with arrows. Some of the metallic colored tape will need to be peeled back in order to access these.
  • The flex cables are held in place using ZIF (zero insertion force) connectors.
  • For the top two and the bottom left (in the photo) the black tab needs to be carefully opened using a plastic prying tool in order to remove the flex cable.
  • For the bottom right connector, the white tab needs to be carefully lifted up with a plastic prying tool in order to release the flex cable.
Insertar traducción aquí
