Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Paso 2
Unscrew 8 T10 screws from the cooling unit. NOTE: these screws are acctually allen keys. The prefered tool will be long handled allen keys. t10 are 2.74mm (closest allen key is 2.5 or 3mm) and t15 are 3.27mm(closest allen key is 3mm and 4mm). You may strip your tool or the actual screws themselves. Use a set of high quality long handled allen keys. The screws are somewhat hidden, so they cannot be see in the picture. To visualize the location of the screws look 3 steps ahead.
  • Unscrew 8 T10 screws from the cooling unit. NOTE: these screws are acctually allen keys. The prefered tool will be long handled allen keys. t10 are 2.74mm (closest allen key is 2.5 or 3mm) and t15 are 3.27mm(closest allen key is 3mm and 4mm). You may strip your tool or the actual screws themselves. Use a set of high quality long handled allen keys.
  • The screws are somewhat hidden, so they cannot be see in the picture.
  • To visualize the location of the screws look 3 steps ahead.
  • The screws will loosen but will not come out, they are designed to loosen the unit, but remain in place.
  • The last two images show another version of the LCS (out of the computer) in the G5 with off-center views to show the 8 screw holes.
Insertar traducción aquí
