Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Holandés
Traduciendo paso 24
Paso 24
iPad Air Repairability Score: 2 out of 10 (10 is easiest to repair) The LCD is easy to remove once the front panel is taken off the iPad.
  • iPad Air Repairability Score: 2 out of 10 (10 is easiest to repair)
  • The LCD is easy to remove once the front panel is taken off the iPad.
  • The battery is not soldered to the logic board. We'll give it that.
  • Just like in previous iPads, the front panel is glued to the rest of the device, greatly increasing the chances of cracking the glass during a repair.
  • Gobs, gobs, and goblins of adhesive hold everything in place. This is the most difficult battery removal procedure we've seen in an iPad.
  • The LCD has foam sticky tape adhering it to the front panel, increasing chances of it being shattered during disassembly.
  • You can't access the front panel's connector until you remove the LCD.
Insertar traducción aquí
