Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Traduciendo paso 3
Paso 3
Use a nut driver to remove the 5 mm Hex standoff securing the ground loop AC inlet cable to the outer case. De-route the AC-in and ground cables from the clips in the outer case.
  • Use a nut driver to remove the 5 mm Hex standoff securing the ground loop AC inlet cable to the outer case.
  • De-route the AC-in and ground cables from the clips in the outer case.
  • Remove the AC inlet from the outer case.
Insertar traducción aquí
