Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
In order to seperate the screen from the motherboard you must disconnect the ribbon attached to the screen. To do this, using tweezers, flip up the cable clamp that is connecting the ribbon to the screen.
  • In order to seperate the screen from the motherboard you must disconnect the ribbon attached to the screen.
  • To do this, using tweezers, flip up the cable clamp that is connecting the ribbon to the screen.
  • Once the clamp is up you can use the tweezers to gently detach the ribbon.
Insertar traducción aquí
