Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y Herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 153 guías que incluyan este paso.
Inglés
Español
Paso 21
Using the opening pick that is still underneath the bottom edge of the iPad, release the adhesive along the bottom left corner. The bottom of the digitizer cable is only ~1" (25 mm) from the bottom of the iPad. Work carefully and slowly, making sure to not sever this cable.
  • Using the opening pick that is still underneath the bottom edge of the iPad, release the adhesive along the bottom left corner.
  • The bottom of the digitizer cable is only ~1" (25 mm) from the bottom of the iPad. Work carefully and slowly, making sure to not sever this cable.
Utilizando la selección de apertura que todavía está debajo del borde inferior del iPad, suelte el adhesivo en la esquina inferior izquierda.
La parte inferior del cable del digitalizador está a sólo ~ 1 "de la parte inferior del iPad.Trabajar con cuidado y poco a poco, asegurándose de no cortar este cable.
[* black] Using the opening pick that is still underneath the bottom edge of the iPad, release the adhesive along the bottom left corner.
[* icon_caution] The bottom of the digitizer cable is only ~1" (25 mm) from the bottom of the iPad. Work carefully and slowly, making sure to not sever this cable.
