Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 7
Insert the pointed end of the a spudger between the protective tape and the inverter board. Carefully pull up with the spudger to lift the inverter board out enough to access the connector cables.
  • Insert the pointed end of the a spudger between the protective tape and the inverter board.
  • Carefully pull up with the spudger to lift the inverter board out enough to access the connector cables.
  • Once you can easily grab the board, pull it up enough to gain access to the inverter board's output connector.
  • Gently remove the board in order to avoid damaging any wires or connectors.
Insertar traducción aquí
