Saltar al contenido principal
Inglés
Español
Paso 7
Perform the following steps once you have installed the new processors and ready to re-install the heatsinks.
Replacement Note: Existing Heatsink
  • Perform the following steps once you have installed the new processors and ready to re-install the heatsinks.
  • Preparing an EXISTING Heatsink for Re-installation. If you have a new heatsink, follow the NEW Heatsink procedure.
  • Using the alcohol pad included with the logic board or processor replacement part, clean off any used thermal grease from the processor and the bottom of the heatsink.
  • Using the thermal grease included with the logic board or processor replacement part, apply one dot of fresh grease to the raised square area on the bottom of the heatsink.
  • Spread the grease evenly across the square to a thickness of approximately 1 mm.
  • Warning: Do not apply more grease than recommended. The grease must not overflow the heatsink and come in contact with the processor connector.
Insertar traducción aquí
