Saltar al contenido principal
Inglés
Español
Traduciendo paso 4
Paso 4
Test for continuity from the bad cylinder (coil pack connector the pcm) all cables have different color so it will be easy to identify. (most of them are in the right corner) In case you don't get continuity this means the cable is broken. ( use a jumper till you  get continuity) test the connector with the jumper cable connected. Assembly the intake manifold and re-test.
  • Test for continuity from the bad cylinder (coil pack connector the pcm) all cables have different color so it will be easy to identify. (most of them are in the right corner)
  • In case you don't get continuity this means the cable is broken. ( use a jumper till you get continuity) test the connector with the jumper cable connected. Assembly the intake manifold and re-test.
Insertar traducción aquí
