Saltar al contenido principal
Inglés
Español
Traduciendo paso 10
Paso 10
Slide the housing back over the magsafe connector. It goes on either way round (there is a hole for the led on both sides.
  • Slide the housing back over the magsafe connector. It goes on either way round (there is a hole for the led on both sides.
  • Squeeze in place with the pliers. If it doesn't fit over the circuit board fairly easily, check that you don't need to file down the solder joints some more.
  • Slide the first of the pieces of heatsink up against the plastic housing.
  • Keeping it tight, shrink it in place. This is important to help avoid a future failure.
  • Repeat with the outermost piece of heatshrink.
  • Try powering it up! Remember that it will take a few seconds before the LED illuminates.
  • Orange light - success!
  • Abrading the top of the casing and applying a big blob of hot-melt glue seemed to provide more permanent, if less elegant, strain relief!
Insertar traducción aquí
