Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 5 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
The two small notched trapezoidal strips will be used to attach the home button bracket to the front panel. Carefully peel off the first trapezoidal adhesive strip with a pair of tweezers.
  • The two small notched trapezoidal strips will be used to attach the home button bracket to the front panel.
  • Carefully peel off the first trapezoidal adhesive strip with a pair of tweezers.
  • Using a pair of tweezers, place the first trapezoidal adhesive strip (minding its correct orientation) on the matching side of the home button mounting bracket.
  • Make sure to line up the profile of the strip with the edge of the mounting bracket.
  • Repeat the procedure for the second trapezoidal adhesive strip.
Insertar traducción aquí
