Saltar al contenido principal
Inglés
Holandés
Paso 6
With our favorite screwdriver set, we remove a few metal connector covers and embark on the epic battle of battery removal. The missing battery pull-tab, though  seemingly innocuous, indicates a bigger problem for battery repair: glue. Perhaps the "s" in 5s stands for "stuck," as in "this battery is stuck in with a lot of glue," or "I hope you didn't want to replace your battery—you're going to be stuck with this one."
  • With our favorite screwdriver set, we remove a few metal connector covers and embark on the epic battle of battery removal.
  • The missing battery pull-tab, though seemingly innocuous, indicates a bigger problem for battery repair: glue.
  • Perhaps the "s" in 5s stands for "stuck," as in "this battery is stuck in with a lot of glue," or "I hope you didn't want to replace your battery—you're going to be stuck with this one."
  • While we'd love a tool-less battery removal as we've seen in other phones, we settle for thermal battery removal via an iOpener.
  • Holy adhesive! It appears Apple ditched the minimal adhesive in the iPhone 5 in favor of those two huge white runways of adhesive holding the 5s(tuck) battery in place.
  • Update: Lots of folks notified us of the peel-able nature of the adhesive strips. We've acquired more iPhones for the repair guides, and we'll adjust the repair score (if needed) once we investigate the issue!
Met onze favoriete schroevendraaierset verwijderen we eerst een aantal metalen covers over de aansluitingen om vervolgens de epische strijd om de batterij aan te gaan.
De ontbrekende treklip onder de batterij, hoewel deze onschuldig lijkt, geeft aan dat ons een veel groter probleem staat te wachten betreffende batterijreparaties: lijm..
Wellicht staat de "s" in 5s voor "stuck", als in "deze batterij is volledig vastgezet met lijm," of "wij hopen dat je niet van plan was ooit je batterij te vervangen—want deze zal voor eeuwig vastzitten."
Hoewel we het bijzonder op prijs zouden stellen als we de batterij konden verwijderen met minder of geen tools, zoals we zagen in andere telefoons, moeten we het in deze telefoon doen met onze iOpener om de batterij te verwijderen.
Holy kleefmiddel! Het blijkt dat Apple de minimale hoeveelheid lijm in de iPhone 5 heeft ingeruild voor twee enorme witte rijbanen aan kleedstrips die de batterij van de 5s(tuck) op z'n plek houden.
Update: Veel mensen hebben ons gewezen op de "afpelbaarheid" van de kleefstrips. We hebben, om de reparatiehandleidingen te kunnen maken, heel wat meer iPhone's in ons bezit gekregen en we zullen daarom ook de repareerbaarheidsscore aanpassen (waar nodig) bij het onderzoeken van verschillende reparaties!
