Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Paso 10
This step is for anti-glare display machines only. Skip this step if you have a glossy display. Remove the two 8 mm Phillips screws securing the Bluetooth/camera cable retainer to the upper case.
  • This step is for anti-glare display machines only. Skip this step if you have a glossy display.
  • Remove the two 8 mm Phillips screws securing the Bluetooth/camera cable retainer to the upper case.
  • One of the screws may remain captive in the Bluetooth/camera cable ground loop. If replacing the display, be sure to transfer this screw to the new unit.
  • Lift the AirPort board/cable retainer assembly out of the upper case.
Insertar traducción aquí
