Saltar al contenido principal
Inglés
Español
Paso 9
This step is for anti-glare display machines only. Skip this step if you have a glossy display. Disconnect the Bluetooth cable by pulling the male end straight away from its socket.
  • This step is for anti-glare display machines only. Skip this step if you have a glossy display.
  • Disconnect the Bluetooth cable by pulling the male end straight away from its socket.
  • Use the flat end of a spudger to carefully pry the AirPort antenna off its socket on the AirPort card.
  • Pull the connector parallel to the face of the logic board, not straight up.
Insertar traducción aquí
