Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 2
Remove the eight Phillips screws securing the heat sink to the logic board.
  • Remove the eight Phillips screws securing the heat sink to the logic board.
  • Keep track of the springs under each of the screws as you remove them.
  • Do not press down on the screws excessively while breaking them free.
  • Carefully lift the heat sink off the logic board.
  • If the heat sink appears to be stuck to the logic board after removing all eight screws, it may be helpful to use a spudger to separate the two components.
  • If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
Insertar traducción aquí
