Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 6 guías que incluyen este paso.
Inglés
Español
Paso 5
The camera cable connector is not secured by any locking or snapping mechanism. Hence, Apple sticks a small strip of black plastic with adhesive applied to the side facing the logic board behind the camera cable connector to keep it in its socket.
  • The camera cable connector is not secured by any locking or snapping mechanism. Hence, Apple sticks a small strip of black plastic with adhesive applied to the side facing the logic board behind the camera cable connector to keep it in its socket.
  • When moving the strip (cable retainer) out of the way, be sure not to break any surface-mounted components off the logic board.
  • Hold the end of the cable retainer down with one finger while you use the tip of a spudger to slightly lift the other end and rotate it away from the camera cable connector.
  • Disconnect the camera cable by pulling the male end straight away from its socket.
  • Pull the connector parallel to the face of the logic board, not straight up.
Insertar traducción aquí
