Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 6 guías que incluyan este paso.
Inglés
Español
Paso 5
Pull the wide tape toward the top of the iPad, applying constant force to release it from the antenna cable between it and the speaker. Slide the tip of a spudger through the gap between the wide tape and the antenna cable, to break the adhesive connecting the two. Continue pulling the wide tape until it is no longer covering the antenna cable.
  • Pull the wide tape toward the top of the iPad, applying constant force to release it from the antenna cable between it and the speaker.
  • Slide the tip of a spudger through the gap between the wide tape and the antenna cable, to break the adhesive connecting the two.
  • Continue pulling the wide tape until it is no longer covering the antenna cable.
Insertar traducción aquí
