Use the flat end of a spudger to disconnect the left fan connector from the logic board.
It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
Atajos de Teclado para Edicion de Pasos de Guia:
Ctrl + Shift + N
Inserta una nueva línea debajo
Ctrl + Shift + P
Inserta una línea encima
Ctrl + ]
Sangrar línea actual
Ctrl + [
Desangrar línea actual
Ctrl + D
Eliminar línea actual
Shift + ;
Navegar al siguiente paso.
Shift + H
Navegar al paso anterior.
Ver todos los atajos
