Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 10
Paso 10
Lay the motherboard down to allow access to the display cable connector. Use the flat end of a spudger to flip the retaining tab on the display cable ZIF connector. Carefully pull the display cable out of its connector as you remove the motherboard from the display assembly.
  • Lay the motherboard down to allow access to the display cable connector.
  • Use the flat end of a spudger to flip the retaining tab on the display cable ZIF connector.
  • Carefully pull the display cable out of its connector as you remove the motherboard from the display assembly.
Insertar traducción aquí
