Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 4
Paso 4
Remove the NFC antenna from the old battery. Use pre-cut double sided tape or Tesa tape to reattach the NFC coil to the replacement battery.
  • Remove the NFC antenna from the old battery.
  • Use pre-cut double sided tape or Tesa tape to reattach the NFC coil to the replacement battery.
  • Before installing the NFC antenna, install the replacement battery and plug in the NFC antenna, to make sure that the antenna is properly aligned.
Insertar traducción aquí
