Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 3
Continue using the opening pick to cut around the NFC antenna, loosening the remaining black adhesive. The NFC antenna should still function normally as long as the plastic layer is not ripped. The NFC antenna should still function normally as long as the plastic layer is not ripped.
  • Continue using the opening pick to cut around the NFC antenna, loosening the remaining black adhesive.
  • The NFC antenna should still function normally as long as the plastic layer is not ripped.
Insertar traducción aquí
