Saltar al contenido principal
Inglés
Español
Paso 12
If you see bulged capacitors, assume there is residual charge. THE FILTER CAPACITOR MUST BE DISCHARGED! IMPORTANT: The black screw marked in blue is a grounding screw. This capacitor is only found on older power supplies. Replacement is advised, but not required. With the power supply shield removed from the monitor, identify the power supply. Take note of the values, including the inverter cap if present.
Remove the power supply
  • If you see bulged capacitors, assume there is residual charge. THE FILTER CAPACITOR MUST BE DISCHARGED! IMPORTANT: The black screw marked in blue is a grounding screw.
  • This capacitor is only found on older power supplies. Replacement is advised, but not required.
  • With the power supply shield removed from the monitor, identify the power supply. Take note of the values, including the inverter cap if present.
  • Remove the 4 screws from the power supply. Once this is done, lift up the power supply at a slight angle to clear the chassis. Do not lift too much or the connector may be damaged!
Insertar traducción aquí
