Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 8 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Lift the hard drive from the edge nearest the logic board and pull it slightly out of its recess. The hard drive is attached by two cables, do not attempt to fully remove it from the iMac. The hard drive is attached by two cables, do not attempt to fully remove it from the iMac.
  • Lift the hard drive from the edge nearest the logic board and pull it slightly out of its recess.
  • The hard drive is attached by two cables, do not attempt to fully remove it from the iMac.
Levanta el disco duro por el borde cercano a la placa lógica y tira ligeramente fuera de su hueco.
El disco duro está conectado por dos cables, no intentes quitarlo completamente del iMac.
