Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 6 guías que incluyen este paso.
Inglés
Español
Paso 2
Use a plastic opening tool to pull the rear plastic cover away from the device until there is enough room to insert a spudger. Insert a spudger under the cover, then pry it up and away from the device. Remove the rear plastic cover from the iPod.
  • Use a plastic opening tool to pull the rear plastic cover away from the device until there is enough room to insert a spudger.
  • Insert a spudger under the cover, then pry it up and away from the device.
  • Remove the rear plastic cover from the iPod.
  • Be very careful in removing the plastic cover as the bluetooth antenna is adhered to it.
Insertar traducción aquí
